Ahmed_Hassouna_
Dec 21, 2017Big-ip throughput in bits/second per Virtual Serve
I want to know if there is any impact on the device resources when using this command "bigtop -n -delay 1"
Hello,
It should not have a significant impact unless your system is very heavily loaded, but you may want to open a second SSH connection and use the 'top' program to observe the CPU usage.
-Josh
- NAG_65570Historic F5 Account
'bigtop' command is not recommended for large and regular stats collections due to performance limitations.
You could use AVR or SNMP instead which can provide more granular stats without compromising performance
