gutiu_220848's avatar
gutiu_220848
Sep 18, 2015
BIG-IP remote logging ASM problem
Hey I´m playing around with the f5 BIG-IP VM v11.6. I want to analyze the attacks on my BIG-IP splunk. Well I built a test environment with kali linux and the LAB lamp server. Everything works pretty fine but I got one Problem: My BIG-IP didn´t send all logged items (like the attack-signatures, signature names) although they were configured for remote logging.
My Big IP detects the attacks inclusive the signature names + signature IDs
This is my BIG-IP remote logging configuration inklusive sig_ids & sig_names
But the BIG-IP didn´t send all of the detected attack-information to splunk
I captured the traffic with wireshark and saw the empty fields
I followed this manual https://devcentral.f5.com/articles/the-big-ip-application-security-manager-part-10-event-logging.Uz3F5bEo7IV
Can anyone help me?
  • nathe's avatar
    nathe
    gutiu, i'm sure i've had these fields populated before. Anyway, the Remote Storage type for Splunk should be "Reporting Server" - have you tried this? Can't be 100% certain it's the resolution but at least it's what it should be configured as. Let me know how you get on with this.
    I think you can also increase the Maximum Entry Length too.
    Rgds
    N
  • I tried out both answers but I didn´t get any sig_ids & sig_names in Splunk =( I am pretty confused because the BIG-IP sends a lot of stuff (like destination IPs …) but not the attack signatures
  • I found a way to get at least some signatures. The detected signatures were in "Staging"> After I Enforce them I got the sigantures in my remote-logging (splunk)
    Is this the right way to do that?
    • nathe's avatar
      nathe
      I think you've hit on the issue here, as items, such as Attack Sigs, when in Staging are "legal" requests in the ASM logs. I suspect, based on this, it doesn't then log the signature itself, even if reported in the GUI.
  • Yes. The attack signature must be in enforce mode if your policy configured as blocking. I was in an impression that your signatures are in enforce mode. You have solved the issue.. Kudos..!!
    Please note, attack signatures you need to manually move to enforce mode after your readiness period as it wont turn on automatically.
    -Jinshu
