Big-IP LTM Esxi comptability issue
Currently we are using Big-IP LTM Virtual edition 10.2.2 and its hosted in ESXi 4.4.Last week our Server team has upgrade the Esxi to 5.5 due to that Big-IP LTM some functions are not working properly.
We are planning to install the Big-IP LTM 12.1.1 in the New VM host. Is it possible to bring all the existing configuration including license from 10.2.2 to 12.1.1?
If it’s possible please provide some inputs to proceed further
- janholtz
Altostratus
I would very much recommend trying to install the target version on the current F5 in another partition, and then try activating with config with the Install configuration option...
Mostly, I think you should check:
https://devcentral.f5.com/questions/need-to-convert-our-ltm-to-ve
//Jan
