big ip has an encountered a configuration problem
hi dc need to know what is the exact issue with this error
installed LTM ve 11 on VMWARE - -virtual machine - 2 GB RAM - 2 CPU - 18 GB HDD physical machine configuration Processor - I 3 RAM - 4 GB HDD- 500 GB
this is due to hardware or some otherthings
- nitass
Employee
did you just upgrade software or restore configuration file?
if yes, try to re-load configuration and see what error is.
tmsh load sys configif you did not upgrade software or restore configuration, try to restart httpd and tomcat and see whether it helps.
bigstart restart httpd bigstart restart tomcat - arunmws_182330
no i just installetd 1 st time it is giving me error i did run those commands but no success - nitass
Employee
which command did you run? what was the output?
- A1_248551
- A1_248551
bigstart restart httpd bigstart restart tomcat these services are runing ok
