BIG-IP Edge client vpn
I have installed BIG-IP Edge client VPN, when I try to connect, I don't see the login screen, all I see is "Checking for Firewall.. " and "Checking for antivirus software", does not show up the login screen. I am using windows 7 and Semantic antivirus. Configured firewall rules to allow this application.
Help is appreciated.
Thanks in advance.
- Domai
Altostratus
I am assuming you setup network access on APM. Did you enable for antivirus and firewall check for connection client on your access policy? If yes disable them and see what happens?
Check the logs to see if it shows anything.
You know you can access it (SSL VPN) via browser as well does that work?
