rfroehling_7678
17 years agoBig IP as a reverse proxy and ldap auth - Java Problem
I try to configure a BIG-IP as a https reverse proxy with LDAP-Authentication. The reverse proxy and the LDAP-auth is working fine. But no I have a "problem" with reauthentication for Java.
So I connect from extern to a https://sitename. I get an authentication window and
do the authentication. I get my webpage and start on this web page a java applet. Now
I get another authentication window for Java from the reverse proxy to do the authentication for the java window again. What I want is a single sign on solution for the source ip address, so that i don't have to reauthenticate in the java window. I saw some sample SSO irules on devcentral, but no one worked for me.
Does anyone have an idea for me?
Kind regards
Ralf
- mar_ou_1_57500
Please does anyone have an idea ?
Thanks in advance.
Best regards
