Best way to capture entire HTTP payload?
I'm trying to write an iRule that - in an event of a request that was blocked by ASM - would capture the entire HTTP payload and send it to a remote syslog server, for further analysis. However I am not quite sure what is the best way of capturing the payload - I tried using HTTP::payload, but for some reason it fails to capture the payload if it exceeds a certain (very small in fact) size, and I haven't been able to find a setting that controls it.
So I am thinking that I must be doing it wrong, but I didn't find a good example of the right way to capture the entire payload.
This is (roughly) what my iRule looks like:
when HTTP_REQUEST { set hsl [HSL::open -proto UDP -pool remote_syslog] ... set http_payload [HTTP::payload] log local0.error "Payload is $http_payload" ... }
when ASM_REQUEST_DONE {
HSL::send $hsl $ASMError
This is a payload that it successfully capture in its entirety:
test
test
test
test
test
test
test
test
test
test
test
But when using the following payload (with an addition of a single element), $http_payload remains completely empty:
test
test
test
test
test
test
test
test
test
test
test
test
Any idea what I'm doing wrong? What is the best way of capturing the whole payload?
you could have a look at HTTP::collect, becomes a bit more tricky, but probably gets the job done.
