mcorvalan_57694's avatar
mcorvalan_57694
May 27, 2011
best practice for ssl ciphers
Hi All:
I send this post to ask you that the last week I have a auditory, an they tell me that I have
Low Strength Ciphers (< 56-bit key).
And I need to change the weak SSL ciphers.
How can I change this option on my LTM 3900?
Since now thanks alot.
Synopsis
The remote service supports the use of weak SSL ciphers.
List of Hosts
Plugin Output
Here is the list of weak SSL ciphers supported by the remote server :
SSLv3
EXP-EDH-RSA-DES-CBC-SHA Kx=DH(512) Au=RSA Enc=DES(40) Mac=SHA1 export
EXP-DES-CBC-SHA Kx=RSA(512) Au=RSA Enc=DES(40) Mac=SHA1 export
TLSv1
The fields above are :
{OpenSSL ciphername}
Kx={key exchange}
Au={authentication}
Enc={symmetric encryption method}
Mac={message authentication code}
{export flag}
  • hoolio's avatar
    hoolio
    You can customize the allowed ciphers for a VS using this SOL
    sol7815: Configuring the cipher strength for SSL profiles
    http://support.f5.com/kb/en-us/solutions/public/7000/800/sol7815.html
    And for the management GUI using this:
    sol6768: Restricting Configuration utility access to SSL clients that are 128 bits or higher
    http://support.f5.com/kb/en-us/solutions/public/6000/700/sol6768.html
    Aaron
  • Ok Aaron thanx alot for replying me asap.
    I think that the last option that u sent me it's gonna be usefully for me, because the problem that i found .
    is the IP 10.100.101.6 it's my managment interface an' not any virtual sever.
