Best choice for automation
Hi, have been playing with automation for a while and so far I've been using excel templates generating tmsh codes I need. Lately I started to play with iControl REST and my excel generates API commands instead of tmsh commands - I did it mostly as template for our automation guys whose are developing applications (orchestrators) able to make a calls to devices (cisco, LBs) and create needed config (partition, VIPs, openings in AFM).
I have a feeling API REST is the easiest way to use API. But our automation team somehow wants still to use tmsh for sending a commands into LB instead of API REST commands. Creating scripts for TMSH is easier for me as well, but it looks like it is not a trend, but API is.
Now the question - as I have to somehow convince our automation team to use API and not bought modules from 3rd parties which can communicate with our LBs through SSH (TMSH).
- So what can be the benefit of having API REST for orchesrating since we could do the same using TMSH?
- I already played with API REST using CURL and I was able to create almost everything. But is the correct way to not use directly these commands (calling them inside PHP for example), but rather create functions in PERL/Python and then call these functions?
- Is it so there is no library of all tmsh commands available for PERL/Python and we have to firstly write each function by ourselves before we can use it?
I am still quite new in this, any advice would really help me.
Thanks, Zdenek
Python was easiest for me. Look how simple this is:
!/usr/bin/python3.4 import requests,json def provisionSoftwareModule(ipAddress,verifyHttpsCert,userName,password,moduleName,provisioningLevel): payload = {} payload['name'] = moduleName payload['level'] = provisioningLevel apiCall = requests.session() apiCall.auth = (userName, password) apiCall.verify = verifyHttpsCert apiCall.headers.update({'Content-Type' : 'application/json'}) apiUrl = 'https://' + ipAddress + '/mgmt/tm/sys/provision/' + moduleName apiResponse = apiCall.put(apiUrl,data=json.dumps(payload)) if not '"generation"' in apiResponse.text: print(apiResponse.text) provisionSoftwareModule('192.168.1.1',False,'admin','mypassword','ltm','nominal')
