Quentin_CARTON_
May 27, 2010Basic Http Load Balancing issue when not using Template wizard
Hi Community.
I'm using the last F5 BIG-IP LTM VE, i would like to create a simple http load balancing. it's works fine when i create it using the default template in templates and wizard/generic http.
When i create my pool / Virtual server manualy, i can telnet the virtual ip/port but the redirection to my pool does not work. I compared the things created by the wizard and mine.. i did not found any difference... I tried to create it using the shell and same issue.
Maybe something i miss. please help!
Thanks in advance.
Quentin.
- hoolio
Hi Quentin,
Do you have SNAT automap enabled on the template virtual server but not on the manually created one?
If that's not the issue, can you reply with the virtual server and pool definitions by running the following commands for both VIPs/pools?
b virtual VIP_NAME list
b pool POOL_NAME list
Thanks, Aaron - Quentin_CARTON_
Thanks for your reply!! Here the conf QC_my_HTTP__virtual_server => Create with template manualVirt => done manually.. I have snat automap enabled with the template.. and not when i create the virtual server manualy.. i have to read the manual to see how enable that... i don't know what used for... bp>b virtual list virtual QC_my_HTTP__virtual_server { snat automap pool QC_my_HTTP__pool destination 192.168.20.200:http ip protocol tcp persist QC_my_HTTP__persist_profile profiles { QC_my_HTTP__http_profile {} QC_my_HTTP__lan-optimized_tcp_profile {} } } virtual manualVirt { translate service disable pool QC_my_HTTP__pool destination 192.168.20.201:http ip protocol tcp httpclass httpclass persist QC_my_HTTP__persist_profile profiles { QC_my_HTTP__http_profile {} tcp {} } } I use the same pool for both VIP... bp>pool list pool QC_my_HTTP__pool { lb method member least conn monitor all http members { 192.168.20.212:http { priority 1 } 192.168.20.213:http { priority 1 } } } - hoolio
You can enable SNAT automap manually under the virtual server properties. Just set SNAT to Automap.
You can also check the box for enabling port translation. And you don't need an HTTP class by default.
Thanks a lot your help was very usefull!
