Basic auth to authenticate against AD
Can I use APM to request basic auth for a virtual server, and have the credentials authenticated against AD? The pool member server has no authentication.
I've seen Kevin's article https://devcentral.f5.com/articles/configuring-apm-client-side-ntlm-authentication, but need to be able to offer basic auth to the client.
I've seen a couple of articles which allude to this ability, but don't provide enough info for me to implement.
- stan_piron
Cumulonimbus
- Basic Auth is supported by APM and provide username / Password
- AD Auth is supported by APM which require username / Password
So Basic Auth against AD is supported..
Basic auth can be activated in 2 modes:
default behavior of APM is
- redirect user to /my.policy
- request 401 authentication
- authenticate provided credentials against authentication server
- redirect user to Landing URI
Clientless mode
- request 401 authentication within an irule
- allow user if authenticated
Clientless mode has some limitations:
- POST are limited to 64KB (extendable to 25MB)
- not available without irule
you can use the following irule to use clientless mode
when RULE_INIT { set static::Basic_Realm_Text "Web Services Authentication" } when HTTP_REQUEST { set apmsessionid [HTTP::cookie value MRHSession] if { [HTTP::cookie exists "MRHSession"] } {set apmstatus [ACCESS::session exists -state_allow $apmsessionid]} else {set apmstatus 0} if {!($apmstatus)} { Insert Clientless-mode header to start APM in clientless mode if { [catch {HTTP::header insert "clientless-mode" 1} ] } {log local0. "[IP::client_addr]:[TCP::client_port] : TCL error on HTTP header insert clientless-mode : URL : [HTTP::host][HTTP::path] - Headers : [HTTP::request]"} } } when ACCESS_POLICY_COMPLETED { Authentication request for non bowser user-agent session denied if { ([ACCESS::policy result] equals "deny") } { ACCESS::respond 401 noserver WWW-Authenticate "Basic realm=\"$static::Basic_Realm_Text\"" Connection close ACCESS::session remove return } }
