Cspillane_18296's avatar
Cspillane_18296
Mar 12, 2010
'b verify load' equivalent?
Hello all,
this is probably an obvious question but i cannot for the life of me find a tmsh equivalent for the bigpipe command 'b verify load' - is there one?
Thanks in advance!
  • There is not. However, you can run it from tmsh:
    run util bigpipe verify load
  • I tried "run util bigpipe verify load" after entering tmsh and I get an error as shown:
    rallsopp@(Active)(/Common)(tmos) run util bigpipe verify load
    Syntax Error: "bigpipe" unexpected argument
    I also don't see bigpipe in the list of commands when I tried "run util ?"
    FYI - we are running version 11.0.0 Build 8037.0 with Hotfix 11.0.0-8131.0 applied on a Big IP 6400 platform.
    Any insight/suggestions ? Thanks as always...
  • I also don't see bigpipe in the list of commands when I tried "run util ?"
    in V11, bigpipe is no longer supported. It's still there, in a "hidden" location, but it's limited in it's functionality. I can't remember the path, but you'll find it with this command: find / -name bigpipe
    Regards
    Kurt Knochner
