ASM XML & JSON parameter learning in Response Body
Hi All,
I'm doing a testing on ASM XML/JSON profile on our lab ASM. I have created XML and JSON profile and assigned to respective URL. Parameter I would like to learn are in response body, response body is in XML and JSON (two different URL one for XML and JSON), But I dont see parameters are getting learned and populated under allowed parameter (request from trusted IP).
Someone could please help me on this: - XML/JSON parameter learning is possible in response body?
Sample response body r4w8173Blad3lyzae
I'm using http://testphp.vulnweb.com/ AJAX for XML testing
Thanks,
Sachin
- Tikka_Nagi_1315Historic F5 Account
Sachin,
The short answer to your question "XML/JSON parameter learning is possible in response body?" is Yes.
Have you had a chance to review documentation? Specifically,
https://support.f5.com/kb/en-us/products/big-ip_asm/manuals/product/asm-getting-started-11-5-0/6.html
SOL13735 - PB identification of JSON parameter type values - http://support.f5.com/kb/en-us/solutions/public/13000/700/sol13735.html?sr=35044458
The manual has a section on JSON parameters - http://support.f5.com/kb/en-us/products/big-ip_asm/manuals/product/asm-config-11-1-0/asm_parameters.html1048180
- sachin_80710
Thanks Tikka.for your resonse,
1) https://support.f5.com/kb/en-us/products/big-ip_asm/manuals/product/asm-getting-started-11-5-0/6.html this is mainly for web service having XML. In my case its JSON parameter in response, how web service policy will work here?
2) https://support.f5.com/kb/en-us/solutions/public/13000/700/sol13735.html?sr=35044458 I have used this option in past with 11.6 ver, but 12.0 ver don't have JSON/XML payload detection under security setting. No idea if this option has move to else where in ASM policy setting.
3) Configuring JSON parameters : This i have tried but not working, also under this topic its written The system validates JSON data found in requests to this parameter based on the settings you configured in the JSON profile. my understanding from this statement is that policy can only learn JSON parameter from request but not from response body. correct me if i'm wrong
Thanks Sachin
