HG's avatar
HG
Icon for Cirrus rankCirrus
Jan 18, 2018
ASM logging error issue
Hi all. Couple of hours ago we have received an error related to asm logging.The cli output is the following when checking the /var/log/asm..................................................................................................................................................................... crit g_server_rpc_handler.pl[21255]: 01310027:2: ASM subsystem error (asm_config_server.pl,F5::ASMConfig::Handler::log_error_and_rollback): DBD::mysql::st execute failed: Table './PRX/REQUEST_LOGPp13000001' is marked as crashed and should be repaired at /usr/local/share/perl5/F5/ASMConfig/Entity/Base.pm line 1380. Does anyone ever had any similar issue in version 13.0.0 HF2 ? The whole implementation is in Microsoft Azure environment.Thanks in advance.
