helyousa_337216's avatar
helyousa_337216
Mar 11, 2019
ASM Event Logging to an FQDN
Hello Guys,
I had to configure an ASM event logging profile to send logs of ASM to an ELK cluster in AWS. This cluster has a dynamic virtual IP changing every X minutes with a static FQDN.
Problem i cannot set a FQDN in the remote logging server in ASM Event profile. I thought to create a virtual server with this ELK cluster and set the IP of my virtual server in the the remote logging server field. But this will cause the traffic to get twice by the BIGIP.
Do you have any ideas ?
Thank you
  • You should be able to configure high speed logging (HSL) with ASM with this guide. When you create the pool of logging servers to send the logs to, you can add a pool member based on a FQDN. This will query the FQDN and return the appropriate IP address.
