Mulham_171271's avatar
Mulham_171271
Nov 28, 2016
ASM: changing hostname for whitelisted URL's
We have ASM policy already in place for site-X.mycompany.com, we have site-Y that hosts the same application but with a different hostname site-Y.mycompany.com
Is there a way to export the ASM policy of site x and change the hostname for the URL's and apply it on site-Y, or I need to build a new policy ?
If this is doable, anything else I need to modify besides URL's hostname ?
  • You can export, and re-use
    The reason for that is if you take a closer look at the meaning of "URL", in BigIP ASM it's really an equivalent to HTTP Path. This means your allowed/disallowed URL definitions are guaranteed to continue working after a DNS update.
    • From the perspective of 'Illegal URL' violation, it doesn't make any slight difference if you update DNS from
      foo.bar.com
      to
      bar.foo.com
    Here's another example:
    • True URL:
      https://devcentral.f5.com/questions
    • BigIP ASM URL:
      /questions
    • Hannes_Rapp_162's avatar
      Hannes_Rapp_162
      Assuming your case weren't so simple, you could always export the policy as XML, and do a 'search & replace all' on the file. Once done, you just import the modified XML as a new policy. Good luck!
      foo.bar.com
      to
      bar.foo.com
    • True URL:
    • BigIP ASM URL:
      /questions
    • Hannes_Rapp's avatar
      Hannes_Rapp
