Brandon's avatar
Brandon
Jan 29, 2019
ASM antibot mobile sdk
We are using the antibot mobile sdk with the app being fused with app dome
the fused app is failing the only thing we see in the logs of the asm is under bot logging cookie missing.
I would like to do a tcp dump or irule to log the cookie from the client. This is in test so not alot of traffic. Just want to make sure the F5 isn't dropping the cookie. there is more then one f5 before the F5 with the
ASM receives the traffic.
