HG's avatar
HG
Icon for Cirrus rankCirrus
Oct 05, 2017
ASM - changes pending on Standby unit.
HI all.I'm expiriencing an issue where standby unit goes into changes pending state. From ASM logs I took the following logs when this was happened.-------------------------------------------------------vm0 info g_server_rpc_handler_async.pl[8803]: 01310053:6: Policy Builder applied security policy "/Common/test-1-Policy".-----------------------------------------------------------------------------------------vm0 info perl[5865]: 01310053:6: ASMConfig change: Apply Policy /Common/test-1-Policy [update] { audit: policy = /Common/test-1-Policy, component = Policy Builder }.-------------------------My question is if there is any option on asm (V13 HF2) where Policy builder can make changes on standby Units ?
  • You can change the device group you are using for ASM sync. Change the sync type to automatic.
