  • mikeshimkus_111's avatar
    mikeshimkus_111
    Historic F5 Account
    Hi Pete, if you are deploying CRM with APM, you should be able to use the f5.microsoft_sharepoint_2010_2013.v1.0.0 iApp template that's up on downloads.f5.com.
    Make sure you enter in the correct URI to monitor in response to the "What HTTP URI should be sent to the servers?" question. For example, mine is /CRM2013/main.aspx where CRM2013 is the CRM deployment name for my test lab.
    We do have a request in for a CRM iApp, but I don't have an ETA on that for you.
    thanks
    Mike
