APM VPN:Assign split-tunnel settings dynamically via RADIUS
Hi there,
is it possibly to dynamically assign included split-tunnel networks (included, so only those subnets will be routed through the VPN tunnel) by using a RADIUS attribute?
Like this I could dynamically assign different split-tunnel networks to different users (I know, this is a very exclusive scenario, but about ~50 different settings are needed within our deployment)
Regards, Saskia
- kunjan
Probably you can try to do a variable assignment after NA resource assignment in VPE
Define the following Configuration Variable:
Type: Network Access
Property: address_space_include_dns_name(Referring to split tunnel included Subnets) -
Assign it the following value,
Agent Type : RADIUS
Attribute Type: Use RADIUS attribute
Radius attribute name : attribute_name_var(Specify)
Value accepted is in 10.0.0.0/255.0.0.0 format.
This doc also might help https://support.f5.com/kb/en-us/solutions/public/13000/000/sol13024
If this radius attribute is under VSA attribute, currently APM doesn't support it.
