APM Portal Access for Oracle application running JInitiator
Hello Experts,
We are experiencing issue publishing IRS oracle pages embeded with jinit.exe
The web page gets ok response and gets stuck on jinit.ext plugin every time I try to open the site and ask for the installation at every attempt.
I download the (around) 80MB plug-in, but even after that, can not connect to the site via Portal Access.
Same access works fine when connected with Network Access and opening the IRS site directly via browser.
Would appreciate the help.
- Michael_Jenkins
What kind of plugin is it using? We had an issue with a Java application because it doesn't send the APM cookie with it's requests. So we had to use an iRule to disable APM for certain URLs by certain User-Agents.
