APM Policy workflow problem
We build a absolute basic APM policy with a Logon Page, AD auth and SSO Credential Mapping.
Then i created a iRule Event directly after the Logon Page and I thought that this Event is called every time a user enters a username/password. The first time that is true but when the user enters a invalid username/password the iRule Event is not called again when the user enters the credentials the second or third time.
Is this a expected behavior and if yes is it possible to changed that?
Background is that we need to get information’s from the user prior to the AD auth to select the DC
- amolari
try this: create a macro with the Logon Page+AD_Query+iRule-Agent, loop it the number of time you want the user to be asked for valid credentials until the Logon_deny. Then in the AD agent set the value "Max logon attemps allowed" to 1
- amolari
you can loop the whole macro for X time. check Manual Chapter: Creating Access Profiles and Access Policies, section "To configure a macro to repeat in an access policy"
