cawong23_136311's avatar
cawong23_136311
Jan 04, 2018
APM on demand cert auth using attribute to map different resource group
Hi F5 buddy,
I currently setup APM using on demand cert auth without LDAP query, I need to use the cert attribute to map different resource group.
The ideal solution is as below:
Cert attribute: CN=AAA, O=F5, O=APM will be map to VPE resource A Cert attribute: CN=BBB, O=F5, O=APM will be map to VPE resource B . . . . etc
The problem is that how I can precisely extract the username "AAA" or "BBB" in VPE to map the resource group?
Many thanks,
Angus
