Max_Q_factor
Cirrocumulus
Feb 27, 2015APM Logout URL trying to logon again using the same browser session
I am running into a problem with an APM Logout URL and SecurID. When I have a user log out of the application the Logout URI configuration removes the session. This is expected and working fine.
The issue I am having is that when the user tries to login again within the same browsing session, a new APM session is created and the user gets an error during login authentication. As far as I can tell in SecurID the error is that the password provided is regarded as null.
Is this expected behavior with Logout URL?
Do your users wind up at the URI /my.logout.php3, and then click the link to start a new session?
By the way, what version are you running?
Thanks, Josh
Do you use an external logon page? If you can provide any configuration examples, it may help.
- Max_Q_factor
Cirrocumulus
No, we use the standard logon page. I will try to get something on the next working day.
