APM close session when smart card removed
Hi ! I have published a web application with smartcard authentication by apm. how do i force closing a session on smart card remove?
Thanks,
Aviv Hassidim
- Henrik_Gyllkran
In normal circumstances the APM doesn't work like that. Once you established a session you're allowed to send traffic until the session ends. What you might be able to do is to create a Per-Request Policy, so that the Access Policy will be verified every time the client sends a rquest. I haven't played around too much with those but I know they don't have all the features of the normal Access Policies, but they might be able to do what you need.
i don't believe APM or any software can do this. the problem is how a smartcard is integrated in the OS. it is just a place to store a certificate, probably with a passcode to protect it. it is accessed when a certificate is requested, but that is it. things like removing a smartcard triggers nothing, certainly not APM.
per access request might help, but it might also just assume the card is still there and use a cached version. i have seen that happen with smart cards and it might differ from OS to OS.
