TPI_144811
Aug 31, 2015APM and 3rd party two-factor authentication
Hello,
Have anyone implemented two-factor authentication by using APM and isprint and VASCO token? Is this possible?
- it depends on what exactly you use from either company, they have quite a range. if they follow the usual standards i don't expect any problems.
Hello,
It looks like i-sprint 2-factor solution support Radius and .Net API. F5 can integrate using Radius AAA servers, HTTP auth or sideband connections for API requests.
