APM ActiveSync - Block or Allow DeviceID
Hello,
I'm setting up a F5 APM with ActiveSync. ActiveSync is working fine. But to add some extra security i want to allow devices by their DeviceID I followed the document "Enhancing Exchange Mobile Device Security with the F5 BIG-IP Platform" Section: "Device Validation Methode 1 - Organization Device Pool"
Step 1: Create a Data Group List (devices) that includes all relevant device IDs Step 2: F5 IRule when HTTP_REQUEST {
Apply DeviceID restriction to all ActiveSync directory traffic if {[HTTP::path] == "/Microsoft-Server-Activesync"} {
Determine whether connection is Base64 encoded, (Windows Phone) and if necessary begin decoding process
set string_b64encoded [HTTP::query]
if {[catch {b64decode $string_b64encoded} string_b64decoded] == 0 and $string_b64decoded ne ""} {
log local0.info "Successful login with deviceID: "
binary scan $string_b64decoded x4H2 IDlenHEX
scan $IDlenHEX %x IDlenDEC
set IDlen {expr "$IDlenDEC * 2"}
binary scan $string_b64decoded x5H$IDlen HEXdeviceID
set string_sentid [string toupper $HEXdeviceID]
set string_sentid [string toupper [URI::query [HTTP::uri]]]
log local0.info "String b64decoded = $string_b64decoded"
compare deviceID presented in HTTP::query with BigIP Data Group List - 'devices'
if {[matchclass $string_sentid contains devices]} {
log local0.info "Successful login with deviceID: $string_sentid"
log local0.info "Failed login with deviceID: $string_sentid"
Step 3 Add iRule to the virtual server
No mather what ID i add to the data group it is not working . Every device can access activesync. Can anyone help me with this.
- Kevin_Stewart
Employee
What log messages are you actually seeing?
I've added some logging below:
when HTTP_REQUEST { Apply DeviceID restriction to all ActiveSync directory traffic if {[HTTP::path] == "/Microsoft-Server-Activesync"} { log local0. "Activesync URI = [HTTP::uri]" Determine whether connection is Base64 encoded, (Windows Phone) and if necessary begin decoding process set string_b64encoded [HTTP::query] if { [catch { b64decode $string_b64encoded } string_b64decoded] == 0 and $string_b64decoded ne "" } { log local0.info "Successful login with deviceID" log local0.info "String b64decoded = $string_b64decoded" binary scan $string_b64decoded x4H2 IDlenHEX scan $IDlenHEX %x IDlenDEC set IDlen { expr "$IDlenDEC * 2" } binary scan $string_b64decoded x5H$IDlen HEXdeviceID set string_sentid [string toupper $HEXdeviceID] } else { set string_sentid [string toupper [URI::query [HTTP::uri]]] } if { [class match $string_sentid contains devices] } { log local0.info "Successful login with deviceID: $string_sentid" } else { log local0.info "Failed login with deviceID: $string_sentid" } } } - Did you ever get this working. Running into the same issue. Could you please comment?
- Peter_L_71637
Hello TJ, We decided to not implement this NOT in our F5 APM. We move this function to our Mobile Device Manager. Sorry i can not help you with this problem. Greeting Peter
