JEFF029
Apr 05, 2018Ansible bigip_pool_member.py the python bigsuds module is required
Hi Everybody,
I try to run playbook with ansible module bigip_pool_member.py to add node in existing pool cause the the python bigsuds module is required.
I did other playbooks to add node, pool or virtual server they work well.
Somebody met this problem ?
Thanks in advance for your help.
- JEFF029
My playbook :
* name: Node jeff hosts: F5_DIJ connection: local tasks: - name: Add a new node bigip_pool_member: server: "{{ ansible_host }}" username: "{{ username }}" password: "{{ password }}" validate_certs: no state: present pool: my-pool partition: Common host: 3.3.3.3 port: 80 description: web server delegate_to: localhostError message :
ansible-playbook F5-ajout-pool-menber-task.yamlPLAY [Node jeff] *********************************************************************************************************** TASK [Gathering Facts] ***************************************************************************************************** ok: [lb-xx.yy TASK [Add a new node] ****************************************************************************************************** fatal: [lb-xx.yy -> localhost]: FAILED! => {"changed": false, "msg": "the python bigsuds module is required"} to retry, use: --limit @/root/ansible/playbooks/F5_playbooks/F5-ajout-pool-menber-task.retry PLAY RECAP ***************************************************************************************************************** lb-xx.yy : ok=1 changed=0 unreachable=0 failed=1Bigsuds installation :
[root@152101lmof ~] sudo pip install --upgrade bigsuds Requirement already up-to-date: bigsuds in /usr/lib/python2.7/site-packages Requirement already up-to-date: suds-jurko>=0.6 in /usr/lib/python2.7/site-packages (from bigsuds)
