advanx_66706's avatar
advanx_66706
Dec 08, 2014
AES256-SHA256 SSL Cipher Suite
I'm sorry if this question is trivial.
I was referring to https://support.f5.com/kb/en-us/solutions/public/11000/400/sol11444.html and I would like to create new HTTPS monitor using AES256-SHA256. What should i put in the Cipher List?
I was guessing that it will be: DEFAULT:+SHA:+3DES:+kEDH:+AES256-SHA256: or DEFAULT:+SHA:+3DES:+kEDH:+AES:+SHA256. No?
BIG-IP 10.2.3
  • i understand bigd uses openssl cipher. i do not see sha256 in cipher list.
    [root@ve10a:Active] config  tmsh show sys version|head
    Sys::Version
    Main Package
      Product  BIG-IP
      Version  10.2.4
      Build    855.0
      Edition  Hotfix HF9
      Date     Thu Oct  9 11:19:27 PDT 2014
    Hotfix List
    [root@ve10a:Active] config  openssl ciphers -v
    DHE-RSA-AES256-SHA      SSLv3 Kx=DH       Au=RSA  Enc=AES(256)  Mac=SHA1
    DHE-DSS-AES256-SHA      SSLv3 Kx=DH       Au=DSS  Enc=AES(256)  Mac=SHA1
    AES256-SHA              SSLv3 Kx=RSA      Au=RSA  Enc=AES(256)  Mac=SHA1
    EDH-RSA-DES-CBC3-SHA    SSLv3 Kx=DH       Au=RSA  Enc=3DES(168) Mac=SHA1
    EDH-DSS-DES-CBC3-SHA    SSLv3 Kx=DH       Au=DSS  Enc=3DES(168) Mac=SHA1
    DES-CBC3-SHA            SSLv3 Kx=RSA      Au=RSA  Enc=3DES(168) Mac=SHA1
    DHE-RSA-AES128-SHA      SSLv3 Kx=DH       Au=RSA  Enc=AES(128)  Mac=SHA1
    DHE-DSS-AES128-SHA      SSLv3 Kx=DH       Au=DSS  Enc=AES(128)  Mac=SHA1
    AES128-SHA              SSLv3 Kx=RSA      Au=RSA  Enc=AES(128)  Mac=SHA1
    RC4-SHA                 SSLv3 Kx=RSA      Au=RSA  Enc=RC4(128)  Mac=SHA1
  • I'm a little bit confused here.
    [root@LORD:Active] ~  tmsh show sys version
    Sys::Version
    Main Package
      Product  BIG-IP
      Version  10.2.3
      Build    123.0
      Edition  Hotfix HF1
      Date     Fri Dec  2 11:43:17 PST 2011
    Hotfix List
    ID372804  ID372864  ID372590
    [root@LORD:Active] ~  openssl ciphers -v
    [root@LORD:Active] ~   tmm --clientciphers 'DEFAULT'
         ID SUITE                          BITS  PROT  METHOD CIPHER MAC    KEYX
     0:   5 RC4-SHA                         128  SSL3  Native RC4    SHA    RSA
     1:   5 RC4-SHA                         128  TLS1  Native RC4    SHA    RSA
     2:   5 RC4-SHA                         128  TLS1.2  Native RC4    SHA    RSA
     3:  47 AES128-SHA                      128  SSL3  Native AES    SHA    RSA
     4:  47 AES128-SHA                      128  TLS1  Native AES    SHA    RSA
     5:  47 AES128-SHA                      128  TLS1.2  Native AES    SHA    RSA
     6:  47 AES128-SHA                      128  DTLS1  Native AES    SHA    RSA
     7:  53 AES256-SHA                      256  SSL3  Native AES    SHA    RSA
     8:  53 AES256-SHA                      256  TLS1  Native AES    SHA    RSA
     9:  53 AES256-SHA                      256  TLS1.2  Native AES    SHA    RSA
    10:  53 AES256-SHA                      256  DTLS1  Native AES    SHA    RSA
    11:  10 DES-CBC3-SHA                    192  SSL3  Native DES    SHA    RSA
    12:  10 DES-CBC3-SHA                    192  TLS1  Native DES    SHA    RSA
    13:  10 DES-CBC3-SHA                    192  TLS1.2  Native DES    SHA    RSA
    14:  10 DES-CBC3-SHA                    192  DTLS1  Native DES    SHA    RSA
    15:  60 AES128-SHA256                   128  TLS1.2  Native AES    SHA256 RSA
    16:  61 AES256-SHA256                   256  TLS1.2  Native AES    SHA256 RSA
    • nitass's avatar
      nitass
      i understand bigd does not use cipher from tmm (tmm --clientciphers).
  • Hi,
    Have u got the https monitor working for sha256?
    Appreciate your response.
    Regards, Midhun P.K
    • boneyard's avatar
      boneyard
      Icon for MVP rankMVP
      try opening a new question with what you tried and your BIG-IP version. also provide the input from openssl ciphers -v ?
