Natthapon_Lohac
Mar 18, 2007AES custom Key possible?
I would like to know if it is possible for us to fix a static key for AES encryption and decryption? Since we need to interact with our partners and vendors, we need to share a common key, but we would like to leverage the capability of the AES feature provided on our BIGIP V9.x , so no recoding of the application is needed.
Your insight is greatly appreciated...
Nat
- bl0ndie_127134Historic F5 AccountNat, you can use a passphrase to generate a AES key instead of a random key; look at the documentation/example for the rule AES::key. So you should be able to share the key with your partners using the shared secret password.
- Deb_Allen_18Historic F5 AccountHey bl0ndie --
Wiki doc doesn't seem to offer any information about using a passphrase to generate a key:
http://devcentral.f5.com/wiki/default.aspx/iRules/AES__key.html (Click here
Should we be looking somewhere else?
(I'd be happy to update the wiki page with more detailed info if you can point us in the right direction.)
thanks!
/deb
