Additional info about iControlREST and OData filtering
I'm interested in finding out more about using the OData $filter keyword to filter iControlREST API results. Jason's article on iControl query params was a good starting point, but I'm getting errors when I try to filter on anything other than partition.
I'm running 11.6.0 Build 4.0.420 Hotfix HF4, and I realize that I might need to upgrade to get the features I want. However, according to the release notes for 12.0 (Fix ID 465197) this is a known issue and only filtering on partitioning is supported. This severely limits $filter's usefulness. Anyone know of plans to expand $filter's use?
Also, I'm wondering if any of the OData operators that would allow inexact/wildcard matches (startswith,endswith,substringof) have been implemented. For example, I'd really like to be able to filter all pool names that start with a certain sequence.
Thanks, Joel
- JRahm
Admin
Only the ASM module fully supports filter at this time.
- Zdenda
Cirrus
Hello, if ASM fully supports $filter and I assume F5 API Rest supports ODATA, what can be the reason of behavior bellow?
Using v12.1.2 VE
This works fine:
[root@f5asmlab:Active:Standalone] config curl -sku admin:admin https://127.0.0.1/mgmt/tm/asm/policies/3ou-5JUctJaKuV1CWZP3pg/blocking-settings/violations?\$filter=contains\(id,\'jXNwalzUiR5DNVbW2Fia7g\'\) | jq . { "kind": "tm:asm:policies:blocking-settings:violations:violationcollectionstate", "selfLink": "https://localhost/mgmt/tm/asm/policies/3ou-5JUctJaKuV1CWZP3pg/blocking-settings/violations?ver=12.1.2&$filter=contains(id%2C'jXNwalzUiR5DNVbW2Fia7g')", "totalItems": 1, "items": [ { "lastUpdateMicros": 1516542355000000, "description": "Access from disallowed Geolocation", "selfLink": "https://localhost/mgmt/tm/asm/policies/3ou-5JUctJaKuV1CWZP3pg/blocking-settings/violations/jXNwalzUiR5DNVbW2Fia7g?ver=12.1.2", "kind": "tm:asm:policies:blocking-settings:violations:violationstate", "violationReference": { "link": "https://localhost/mgmt/tm/asm/violations/GRBzLnLpxuzm2dcWZQr76A?ver=12.1.2" }, "id": "jXNwalzUiR5DNVbW2Fia7g", "alarm": true, "block": true, "learn": true } ] }But this not and result message about some DB issues is strange:
`[root@f5asmlab:Active:Standalone] config curl -sku admin:admin https://127.0.0.1/mgmt/tm/asm/policies/3ou-5JUctJaKuV1CWZP3pg/blocking-settings/violations?\$filter=contains\(description,\'Geolocation\'\) | jq . { "code": 500, "message": "DBD::mysql::st execute failed: Unknown column 'policy_id' in 'group statement' at /usr/local/share/perl5/F5/ASMConfig/Entity/Base.pm line 1296.", "referer": "127.0.0.1", "restOperationId": 55423489, "kind": ":resterrorresponse" } `/var/log/Restjavad.0.log:
`[SEVERE][12150][11 Jun 2018 09:56:22 UTC][com.f5.rest.workers.asm.AsmConfigWorker] nanoTime:[18666043711136120] threadId:[20] Exception:[ASMConfigException(error_message:DBD::mysql::st execute failed: Unknown column 'policy_id' in 'group statement' at /usr/local/share/perl5/F5/ASMConfig/Entity/Base.pm line 1296., internal_error:DBD::mysql::st execute failed: Unknown column 'policy_id' in 'group statement' at /usr/local/share/perl5/F5/ASMConfig/Entity/Base.pm line 1296., rest_code:REST_INTERNAL_SERVER_ERROR) at com.f5.asmconfig.ASMConfig$rest_call_result$rest_call_resultStandardScheme.read(ASMConfig.java:12388) at com.f5.asmconfig.ASMConfig$rest_call_result$rest_call_resultStandardScheme.read(ASMConfig.java:12366) at com.f5.asmconfig.ASMConfig$rest_call_result.read(ASMConfig.java:12308) at org.apache.thrift.TServiceClient.receiveBase(TServiceClient.java:78) at com.f5.asmconfig.ASMConfig$Client.recv_rest_call(ASMConfig.java:458) at com.f5.asmconfig.ASMConfig$Client.rest_call(ASMConfig.java:443) at com.f5.asmconfig.client.AsmClient.rest_call(AsmClient.java:61) at com.f5.rest.workers.asm.AsmConfigWorker.restCallWithRetry(AsmConfigWorker.java:155) at com.f5.rest.workers.asm.AsmConfigWorker.forwardCall(AsmConfigWorker.java:178) at com.f5.rest.workers.asm.AsmConfigWorker$1.run(AsmConfigWorker.java:135) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) at java.util.concurrent.FutureTask.run(FutureTask.java:262) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:178) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:292) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:745) ]client:[30938884]- Zdenda
Cirrus
The issue above is due to incompatibility with v12. OData for those cases seems fully supported since v13.1 - info from F5 support
- Zdenda_101923
Altocumulus
Using v12.1.2 VE
This works fine:
`[SEVERE][12150][11 Jun 2018 09:56:22 UTC][com.f5.rest.workers.asm.AsmConfigWorker] nanoTime:[18666043711136120] threadId:[20] Exception:[ASMConfigException(error_message:DBD::mysql::st execute failed: Unknown column 'policy_id' in 'group statement' at /usr/local/share/perl5/F5/ASMConfig/Entity/Base.pm line 1296., internal_error:DBD::mysql::st execute failed: Unknown column 'policy_id' in 'group statement' at /usr/local/share/perl5/F5/ASMConfig/Entity/Base.pm line 1296., rest_code:REST_INTERNAL_SERVER_ERROR) at com.f5.asmconfig.ASMConfig$rest_call_result$rest_call_resultStandardScheme.read(ASMConfig.java:12388) at com.f5.asmconfig.ASMConfig$rest_call_result$rest_call_resultStandardScheme.read(ASMConfig.java:12366) at com.f5.asmconfig.ASMConfig$rest_call_result.read(ASMConfig.java:12308) at org.apache.thrift.TServiceClient.receiveBase(TServiceClient.java:78) at com.f5.asmconfig.ASMConfig$Client.recv_rest_call(ASMConfig.java:458) at com.f5.asmconfig.ASMConfig$Client.rest_call(ASMConfig.java:443) at com.f5.asmconfig.client.AsmClient.rest_call(AsmClient.java:61) at com.f5.rest.workers.asm.AsmConfigWorker.restCallWithRetry(AsmConfigWorker.java:155) at com.f5.rest.workers.asm.AsmConfigWorker.forwardCall(AsmConfigWorker.java:178) at com.f5.rest.workers.asm.AsmConfigWorker$1.run(AsmConfigWorker.java:135) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) at java.util.concurrent.FutureTask.run(FutureTask.java:262) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:178) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:292) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:745) ]client:[30938884]- Zdenda_101923
Altocumulus
