Jonathan_Scholi
Aug 23, 2011Add health monitor to pool using Java iControl
Are there any code examples of how to add a health monitor to a pool using a Java iControl?
- John_Gruber_432Historic F5 AccountUsing the axis wsdl2java classes.. I use the jar file downloaded from labs section of dev central. This is a code snippet that creates a single monitor on a LocalLB::Pool.
iControl.LocalLBPoolLocator node_locator = new iControl.LocalLBPoolLocator(); iControl.LocalLBPoolBindingStub stub = (iControl.LocalLBPoolBindingStub) node_locator.getLocalLBPoolPort([BIGIPURL]); String[] monitors = new String[1]; monitors[0] = monitor_name; iControl.LocalLBMonitorRule rule = new iControl.LocalLBMonitorRule(); rule.setQuorum(0L); rule.setType(iControl.LocalLBMonitorRuleType.MONITOR_RULE_TYPE_AND_LIST); rule.setMonitor_templates(monitors); iControl.LocalLBPoolMonitorAssociation[] monitor_associations = new iControl.LocalLBPoolMonitorAssociation[1]; monitor_associations[0] = new iControl.LocalLBPoolMonitorAssociation(); monitor_associations[0].setMonitor_rule(rule); monitor_associations[0].setPool_name(pool_name); stub.set_monitor_association(monitor_associations);
You will want to see what monitor rule types are possible so you get what you want. - Jonathan_Scholi
Thanks, I'll give it a try.
