Ossar_178453's avatar
Ossar_178453
Mar 06, 2015
Active-active with single traffic group
Hello,
I am running a small test cluster of two BigIP VEs. All the failover objects are in a single traffic group but somehow both units consider themselves active. Configuration sync works fine so they have contact and awareness of each other.
I need them to be an active-standby cluster and as far as I understand this will be the default when you only have one traffic group, the default one.
 list cm traffic-group
cm traffic-group traffic-group-1 {
    ha-order {
        unit1.secret.name
        unit2.secret.name
    unit-id 1
cm traffic-group traffic-group-local-only {
    is-floating false
  • nathe's avatar
    nathe
    Ossar,
    Under Device Management - Devices - "device name" have you configured Network Failover here?
    Add in your HA or internal VLAN details here and the Management Address too.
    Hope this helps,
    N
