Bruce_Walker_11's avatar
Bruce_Walker_11
Jun 24, 2010
Active / Standby Failover between BIGIP 1600 and 6400
Haven't been able to find anything on the askF5 or Devcentral site as to whether the following is possible or not:
Currently I have two 6400's setup, need to break the pair and set one up at another data center, wanted to use the 1600 in the meantime as a fallback.
I was just looking to do network based failover between the two units. They would be using VLAN and Gateway Failsafe.
The end goal would be active / standby failover with BIGIP 6400 as the Active unit and BIGIP 1600 as the standby. Both are running:
BIG-IP Version 9.4.5 1086.1
Hotfix HF2 Edition
The 6400 has more interfaces configured into Trunks (6 copper) and the 1600 has only 4 copper which is one problem I can see.
Unfortunately I don't have enough spare equipment to test this.
Any thoughts?
Thanks,
Bruce
  • I don't see why it would be a problem - the failover mechanism should only care about the network transport protocol - which has issues between versions, but shouldn't between hardware. The trunk differences wouldn't be copied in a sync anyways so I don't see a problem - might be one of those "works but F5 doesn't recommend" type of scenarios.
  • Posted By Bruce Walker on 06/28/2010 05:07 PM
    Thanks Chris,
    I'll give it a shot, fingers crossed.
    Bruce
    Let us know how it goes Bruce - it's actually a really cool scenario. In my case, I have 8900s as both active and standby because I'm in retail and can't afford issues if a smaller unit couldn't handle traffic - for some businesses though, a smaller unit as a standby might not be a bad idea - especially if money is tight and you just need something to handle traffic during emergencies or maintenance.
  • Steve_Scott_873's avatar
    Steve_Scott_873
    Historic F5 Account
    Be interested to know as well. We're going to be upgrading when our 6400s go EOSD in a year and a bit. Would be interesting to know if i can just slot the new model in and restore the backup from the enterprise manager.
  • Posted By Steve Scott on 06/29/2010 06:48 AM
    I don't think you'll be able to do that too easily - while failover isn't a big deal between units, config sync/restorations definitely are. You'd for sure get a licensing issue since your config file would have an existing license but you could get around that simply be relicensing the new unit - your problem will be that the config file contains unit specific information like interfaces and what not - your best bet might just be to copy the files that aren't unit specific.
    Steve_Scott_873
    Historic F5 Account
    We'd get the licensing issue when we replace the unit from an RMA, thats fairly easy to deal with. I guess the platform specifics depend on interface numbers more than anything. If they're the same then I guess it should work. If they're different I guess i need to alter bigip_base.conf and correct those.
  • Posted By Steve Scott on 06/30/2010 05:17 AM
    Exactly - it'd just be modifying certain files - which you could probably do from within the UCS archive too if you wanted to restore via that method instead of file copies.
