Accessing OWA using APM
I am attempting to use 1 big ip running APM to allow secure remote access to another big ip running LTM and load balancing several client access servers. However, when logging into the secure logon page the page just spins. I have performed network captures on both big ips and I never see an attempt to reach the client access server. Any thoughts? I am running BigIP 11.5.1 VE.
The last 2 events in the APM log are following rule 'fallback' from item 'SSO Credential Mapping' to ending 'Allow' and then Access Policy result: LTM+APM_mode.
- Kevin_Davies_40
Nacreous
Does the VPN tunnel start for you?
- Dev_56330
Cirrus
VPN tunnel? How can I validate this? I was unaware of any VPN tunnel for OWA access.
- Matt_Dierick
Employee
And where is the ressource in your APM bigip ? After SSO Credential Mapping, you need to assign ressources (from a webtop or from a LTM pool in your VS settings).
I suppose your are using VPN SSL with a network access ressource ?
