AJ_339426's avatar
AJ_339426
Jan 04, 2018
A way to send the monitor status?
I'm trying to find a way to send the https monitor pool member status, or a REST call to a particular url when the response is other than 2xx, in order to trigger an API workflow. Any help would be greatly appreciated!!
  • How about this, with which you can capture your required values and use it.
    /mgmt/tm/ltm/pool/dummy-pool-name/members/stats
  • iCall is an option, you can setup an iCall script to trigger on an event.
    For this you would setup an iCall script to call your external API. Then need a handler based on a trigger and finally need to edit the /config/user_alert.conf to add in the event.
    See the following codeshare for example of triggering a tcpdump on a pool member going down. Run tcpdump on event
    For more info on iCall see What is iCall?
