AddeparNR_25346's avatar
AddeparNR_25346
Mar 08, 2016
404 Not found when trying to hit the saml login flow
I've followed the instructions on this page, but when using the external IDP login button it redirects to a 404 page.
I've configured the virtual server, the SP service to bind to the External idp connector and the access policies, but have had no luck. Any ideas?
  • Hello,
    The best would be to import the metadata from the external IDP to the BIG-IP to avoid any issues.
    Maybe, you should check the url of the IDP you configured in your IDP connector.
    Have a look at your IDP configuration.
    You also can use firefox with SAML tracer plugin to track SAML requests and assertions
