rajesh_74821
Sep 01, 2009(401)F5 Authorization Required
Hi all.
With the using of sample application java from http://devcentral.f5.com/Default.aspx?tabid=125
it is giving exception.
i was changed the url in ConfigSync file of iControlIntermediary for local testing purpose. the url is as follows
from https://[username]:[password]@[ipAddress]/iControl/iControlPortal.cgi url to
http://[ipAddress]/iControl/iControlPortal.cgi?username=[username]&password=[password] url
then i am getting the (401)F5 Authorization Required error messages.
so any body can help me.
Rajesh R
- See my response in this thread:
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=1&tpage=1&view=topic&postid=6199862018
Click here
I'm working on a fix right now but in the mean time if you could remove The "@" and "" characters from your password you should be good.
-Joe - Justin_R_298703
I am sure you have figured this out by now, but wanted to post my findings. Maybe it can help others. I was having the exact same issue / error. It turns out it was a lack of permissions on the LTM. You must be an administrator on the LTM to use IControl rest. Once i had my permissions changed it worked as expected.
