kridsana's avatar
kridsana
Feb 07, 2013
3600 and 10.2.4 and product metric
Hi
I have some question about software that support with BIG-IP 3600
from this SOL : http://support.f5.com/kb/en-us/solutions/public/9000/400/sol9476.html
you can see 10.2.4 is supported
but from this metric : https://docs.google.com/viewer?url=http%3A%2F%2Fsupport.f5.com%2Fcontent%2Fdam%2Ff5%2Fkb%2Fglobal%2Fsolutions%2Fsol10288_images.html%2Fbig-ip-product-matrix.pdf
you can see 3600 is supported until 9.4.6
This is currently active module.
active module : ADD 100 MBPS COMPRESSION| ADD 100 MBPS COMPRESSION
active module : ADD 100 MBPS COMPRESSION| 100 MBPS COMPRESSION
active module : Local Traffic Manager, 3600 Local Traffic Manager Module|ADD IPV6 GATEWAY|ADD RATE SHAPING|ADD RAMCACHE|50 MBPS COMPRESSION|SSL 500 TPS Per Core|ADD SSL CMP|ADD ANTI-VIRUS CHECKS|ADD BASE ENDPOINT SECURITY CHECKS|ADD FIREWALL CHECKS|ADD MACHINE CERTIFICATE CHECKS|ADD NETWORK ACCESS|ADD PROTECTED WORKSPACE|ADD SECURE VIRTUAL KEYBOARD|ADD WEB APP
Can I upgrade to v. 10.2.x or 11.x with this platform?
Thank you
  • nathe's avatar
    nathe
    I'd go by sol9476 which says the 3600 does support 10.x and 11.x.
    In fact we've got 3600s running 11.2.x.
    Hope this helps,
    N
  • So we can install 10.2.4 or 11.2.1 in 3600
    but i'm not sure because SOL is say support ,but in big-ip product matrix isn't say support -_-
  • but i'm not sure because SOL is say support ,but in big-ip product matrix isn't say support -_-you may open a case to correct the sol.
