MR_Freddy's avatar
MR_Freddy
Feb 20, 2018
304 Response code failure with java script Application
We have a problem with 304 response code
First Scenario:
-> VS listen on HTTPS and Server on HTTP with client SSL profile only with automap
-> Here we viewed that GET HTTP request sent with more header than the second scenario with "if modified since" header and "if none match" header
-> Which caused server respond with 304 response code
All 304 response code appeared with URL contain "JS" only
Second Scenario:
-> VS listen on HTTP and server on HTTP with automap
-> Here Server respond without any "if modified since" header and "if none match" header
-> As well as the server respond with 200 response code
