chin_15339's avatar
chin_15339
Apr 14, 2017
Solved
2 way ssl not working with open ssl generated certificates
Jan 1 19:13:56 bigip1 warning tmm[11040]: 01260006:4: Peer cert verify error: certificate is not yet valid (depth 0; cert /C=IN/ST=KTK/O=Chase/OU=IT/CN=testing141) Jan 1 19:13:56 bigip1 warning tmm[11040]: 01260009:4: Connection error: ssl_shim_vfycerterr:4530: certificate is not yet valid (45) Jan 1 19:13:56 bigip1 info tmm[11040]: 01260013:6: SSL Handshake failed for TCP 192.168.166.1:39596 -> 192.168.166.20:443 Jan 1 19:13:57 bigip1 warning tmm[11040]: 01260006:4: Peer cert verify error: certificate is not yet valid (depth 0; cert /C=IN/ST=KTK/O=Chase/OU=IT/CN=testing141) Jan 1 19:13:57 bigip1 warning tmm[11040]: 01260009:4: Connection error: ssl_shim_vfycerterr:4530: certificate is not yet valid (45) Jan 1 19:13:57 bigip1 info tmm[11040]: 01260013:6: SSL Handshake failed for TCP 192.168.166.1:39598 -> 192.168.166.20:443
  • The problem is Connection error: ssl_shim_vfycerterr:4530: certificate is not yet valid
    If you are seeing this then its likely the time on you BIG-IP needs to synchronised.
    Set a DNS server
    System -> Configuration -> Device -> DNS add 8.8.8.8
    Set an NTP Server
    System -> Configuration -> Device -> NTP add pool.ntp.org
    If the time does not update within a minute check you can reach your DNS server. From the command line
    ping 8.8.8.8
    If the system has never been synced before then run the following...
    service ntpd stop
    ntpdate pool.ntp.org
    service ntpd start
    This will force time to sync no matter the time difference.
    Set a DNS server
    Set an NTP Server
    ping 8.8.8.8
    service ntpd stop
    service ntpd start
    • chin_15339's avatar
      chin_15339
      Thanks Kevin for the update. This is our lab device so we dont have a DNS as such, when you say time sync does that mean the Certificate Authority issued issued certificates and the LTM device clock should be in sync or the end machine which is accessing the URL should be in sync
    • Kevin_Davies_40's avatar
      Kevin_Davies_40
      They all need to be in sync. Real time or your own time, all of then need to have the same time. When they are too far out SSL will not work.
      chin_15339
      Thanks Kevin it really works Sync is required.
      Thanks a ton :-)
