2 rules in same VIP
Hi
I want to apply 2 different iRules in a VIP, one iRule is already applied on the VIP and need to apply 1 more for HSTS.
please let me know, do i need to merge the new one to existing one or i can apply both independently one after the other.
And need to apply the below one also on the same VIP
ltm rule hsts_insert_rule {when HTTP_RESPONSE
{ HTTP::header insert Strict-Transport-Security "max-age=31536000" } }
- zeiss_63263Historic F5 Account
You can apply multiple iRules to a Virtual Server. They are evaluated in order.
create ltm virtual myvirtual destination 1.1.1.1:80 rules { myrule_two myrule_one } list ltm virtual myvirtual ltm virtual myvirtual { destination 1.1.1.1:http mask 255.255.255.255 profiles { fastL4 { } } rules { myrule_two myrule_one } source 0.0.0.0/0 translate-address enabled translate-port enabled vs-index 3 }You may create or modify either via tmsh, REST or the web UI.
- usengar-oracle_
Do we need to set some priority too on these iRules..?
however they are for different Events..
first one checked white-listing of source IP, if source IP exist in the list then allowed to access the VIP and the other one is for HSTS..
first one is already applied so we need to modify the VIP config, is below config correct..?
modify ltm virtual /Public/vs_htsvhypdev1_em3_xxx_com_443_new rules { saas_sdi_vpn_whitelist_rule hsts_insert_rule }
