blade management ip
1 TopicAdding Viprion Blade Management Address in Production
Hi every one. I have 2 Viprion with 2 blade cluster identic on each viprion. i have situation were when i create a new vcmp guest on Viprion02 and assign an ip address, that ip address is unreachable from the network (all other vcmp guest is reachable). When i checked on the bash linux for the mgmt address, there is no ip address were on the system-platform i can see the same ip address for the management. But this issue is not happen on Viprion01. I take a look for the viprion02 cluster blade. Only cluster IP is configured and No blade management ip is configured. Not like in Viprion01, All blade have its own management IP. I would like to add management ip address on Viprion02 blade. 1. Will there is an impact on the production? I have tried read about the viprion and assume it should not give any impact due to management ip is distinct with management blackplane were used for blade inter communication, traffic handling, and sync. 2. Which HA is that doc talking about? Blade HA is active active right? And Guest HA using its own management IP, not the blade management address. Thank You887Views0likes1Comment
