04-Sep-2020 03:19
Need iRule help connection limite and redirection
Requirement : we have two set of pool A & B, pool A having 8 nodes, Pool B having 3 node
We have to limit the connection 3000 on pool A and renaming new connection flow to pool B
If the active connection is less than 3000 new connection flow to pool A
30-Sep-2020
08:44
- last edited on
04-Jun-2023
21:16
by
JimmyPackets
You can probably reference this other DevCentral post to get most of the way to your goal, https://devcentral.f5.com/s/question/0D51T00006i7TIA/connection-limit-on-virtual-server
The iRule below is an example I created but has not been tested for functionality or requirements.
when RULE_INIT {
set ::active_connections 0
set ::max_connections 3000
when CLIENT_ACCEPTED {
#Check if we're over the maximum allowed connections
if {$::active_connections > $::max_connections } {
# We're over the max, send to pool B
pool B
# We're not over the max, so send to Pool A and increment active_connections
incr ::active_connections 1
pool A
when CLIENT_CLOSED {
# A connection was closed, so decrement the global counter
incr ::active_connections -1
