Joel_Breton's avatar
Joel_Breton
May 24, 2017
Using the Python SDK for monitors
I'm starting to use the python SDK and I can't figure out how to access the monitor objects on the BIGIP.
Here's my code for displaying the nodes
from f5.bigip import ManagementRoot
mgmt = ManagementRoot('IP Address', 'user', 'password)
nodes = mgmt.tm.ltm.nodes
for node in nodes.get_colletion():
    print(node.name)
Here's my code for displaying the monitors
mgmt = ManagementRoot('ip address', 'user', 'password')
monitors = mgmt.tm.ltm.monitors
for monitor in monitors.get_collection()
    print(monitor.name)
I read the documentation located http://f5-sdk.readthedocs.io/en/latest/index.html
The difference between monitors and node in the documentation is the (star) * is separated by colon in the node portion. Don't know if that makes a difference. REST Kind -> tm:ltm:monitors* REST Kind -> tm:ltm:node:*
Any thoughts would help
  • (YMMV depending on version. I'm using version 12.1.2.)
    'monitor' is another collection with the various monitor types underneath it. If you just get the collection from 'monitor' you'll have a list of reference links to the sub-collections underneath it. One way of getting an actual list of monitors is to get the collection of the specific monitor type:
    >>> https_monitors = mgmt.tm.ltm.monitor.https_s.get_collection()
    >>> for mon in https_monitors:
    ...     print(mon.name)
    Reminder that since the monitor objects are collections, they'll end in 's', or '_s' if the resource already ends in 's'. Example: to get https monitors, use 'https_s'. To get http monitors, use 'https'.
    Apologies if I've butchered SDK terminology on collections/sub-collections. I'm still getting used to the environment myself.
  • Hi guys,
    how can I create a new monitor using the Python SDK?
    Unfortunately
    monitor = mgmt.tm.ltm.monitors.monitor.create(partition='Common', name='MyMonitor01')
    is not working.
    AttributeError: '' object has no attribute 'monitors'
    regards
    Daniel
  • I'm trying to get a list of all available monitors. Is there a way to loop through the monitor types to then do a get_collection():
    for monitor in mgmt.tm.ltm.monitor.get_collection():
            for item in monitor.get_collection():
                    pprint(item)
    This clearly doesn't work
    • Rob_74473's avatar
      Rob_74473
      Icon for Cirrus rankCirrus
      It seems I'm not allowed to edit an answer...
      What I'm trying to achieve is a select field in a web page that mirrors the behavior of the Health Monitors section of a pool properties page in the BigIP gui, so that I can add/remove monitors from a pool through the rest api.
