mplaksin_293271
8 years agossh_exchange_identification: read: Connection reset by peer lost connection
When i try to do SCP to my VCMP i have the error : [root@~] scp testfile root@10..81:/ ssh_exchange_identification: read: Connection reset by peer lost connection Same with winSCP. But i can do SSH without problems.
- jaikumar_f5
Noctilucent
Weird. SSH & SCP both use the same default port. Unless its an exception.
- Anesh
Try the below
- vi ~/.ssh/known_hosts from the host you are trying to connect from - search for host you are trying to connect to - delete the entry
