Technical Forum
Custom Alert Banner
Simple iRule to route to particular pools based upton a specific header value.
viziony
Cirrus
Cirrus
I am hoping this is a simple ask (nobbie in iRule scripting) , I am trying to create an irule that will route to specific pools based up on cookie header value.
For e.g.
Cookie header "Toggle"
Value "Y" or "N"
If toggle = Y goto Pool A
If toggle = N goto Pool B
2 ACCEPTED SOLUTIONS
Hi @viziony ,
Could you please try this :
if { [HTTP::header "Toggle"] equals "YES" }{
    pool pool_A
    pool pool_B
#you can replace "equals" operator by "contains"
Try it and give me your feedback
hope this helps you.
_______________________
Regards
Mohamed Kansoh
Leslie_Hubertus
Community Manager
Community Manager
Hi @viziony  - it looks like you gave a kudo to @Mohamed_Ahmed_Kansoh 's reply, so I'm going to mark that as the Accepted Solution to make it easier for someone else to see the answer. If that answer didn't help you, please let me know so I can change that status. 🙂
4 REPLIES 4
viziony
Cirrus
Cirrus
Would it be something like this
if { [HTTP::header "Toggle"] is "YES"  }
{ pool pool_A }
else
{ pool Pool_B } }
Hi @viziony ,
    pool pool_A
    pool pool_B
Regards
Mohamed Kansoh
Hi Viziony,
You can also try,
when HTTP_REQUEST{
if { [string tolower [HTTP::header values "Toggle"]] contains "YES"} {
pool pool_A
pool pool_B
Here are few links for further ready:
K27803480: iRule for selecting a Pool or Pool-member based on HTTP Request URI contents.
https://support.f5.com/csp/article/K27803480
See more articles here
DevCentral Technical Articles iRules 101 - #05 - Selecting Pools, Pool Members, ...
https://community.f5.com/t5/technical-articles/irules-101-05-selecting-pools-pool-members-and-nodes/...
Clouddocs > > HTTP::header
https://clouddocs.f5.com/api/irules/HTTP__header.html
iRules Recipe 3: Pool and SNAT Selection by Host Header Value
https://community.f5.com/t5/technical-articles/irules-recipe-3-pool-and-snat-selection-by-host-heade...
https://community.f5.com/t5/codeshare/select-pool-based-on-http-host-header/ta-p/278199
Cooking with iRules - HTTP
https://readthedocs.org/projects/f5-agility-lab-template/downloads/pdf/latest/
HTH
Leslie_Hubertus
Community Manager
Community Manager
