Marta's avatar
Marta
Aug 07, 2020
Sharepoint+AD+DUO
Hi all,
I have created an APM policy for sharepoint which is AD + DUO.
This works correctly, the problem I have is that when I enter sharepoint it has embedded applications that all respond to the same virtual IP.
This causes that every time I change the application, it redoes the entire authentication process.
Has it happened to someone? Do you know if there is some way of not asking for authentication if we have already authenticated once?
Thank you very much,
Regards
Marta Marcos
