Steve__Parker_7
Mar 15, 2005Nimbostratus
Setting pool member ratio
We want to use an adaptive type load balancing method.
Can we use LocalLB.PoolMember.set_ratio to dynamically affect the Ratio load balancing method?
Or do we use the Dynamic Ratio load balancing method and use LocalLB.PoolMember.set_dynamic_ratio? But, the documentation on load balancing methods indicate the Dynamic Ratio type is used with a specific performance monitor.
