mat_d's avatar
mat_d
Dec 02, 2021
Solved
Serving Moodle App - problem when using https
Hello,
I have a problem with serving to moodle app using f5.
When I have prepared VS for HTTP traffic everything works fine, but when I overfloating SLL external content like stylesheet is blocked.
I don't have any idea where might be a problem. Other apps work fine, but only moodle has that problem with serving external content.
I'll be grateful for any response
Regards,
Mateusz
  • Hi Mateusz,
    If the page contains http and https content, web browser will block the http content.
    https://support.f5.com/csp/article/K31100432
  • Hi Mateusz,
  • mat_d's avatar
    mat_d
    My colleague discovered an "interesting" error. When I use https the enclosed media displayed ok but the SVG graphic won't display on the web page.
    I switched to the http, and everything is displaying properly, and graphics from the template are present for a user..
    There are any templates ready-to-use or best practices dedicated to the moodle?
